Don’t expect that you will read the whole manual through.
RocRail manual is for those who understand RocRail concept. After you understand the concept, then you dig around on topic you want to know more.
What is RocRail concept?
All tracks must be defined in “block”. Each locos runs from block to another block and so on.
Normally, there is NO 2 locos in the same block, except it is staging block. (where you park your loco in the same track). Staging block needs different configuration.
Each block starts and ends at the turnout (or switch). Turnout/switch is not in any block at all. You read more from here.
Block is the smallest element in automation system.
When you set block, then you set some route.
Each block will have at least 2 sensor for one train direction. If this block for two-way train direction, you will need 4 sensor.
When you have some block picture in your mind, then you start do some sensor track, sensor box (S88), some wiring from S88 back to command station.
If you come to this far, we can discuss more on software configuration.
